Need help don’t know where to start
hey guys I just bought a 97 bubble a couple months ago replaced the b18b1 integra motor it came with, with the same engine not shortly after the clutch now goes all the way down to get into gear like it lost pressure since that happened it was a struggle to get into most gears except fourth. Hada start double clutching down to the floor to get it into gears n now it just plain won’t go into gears at all even tried slamming the shifter to get into gear there’s no(1,2,3,4,5 or reverse ) that the shifter will go into any ideas on what the issue could be please help thank you much appreciated
Did you replace your clutch master cylinder with the swap? It could have just gone bad. Or maybe just needs to be bled. Does it go into gear when the car is off?
Dav94Lx
Feb 2, 2008 07:53 AM
P-DuBB
May 29, 2006 03:17 PM
