Transmission & Drivetrain Gearboxes, Differentials, Clutches
00 honda accord v6 transmission problem
Old Jun 18, 2018 | 11:57 AM
soulcalibur's Avatar
Default 00 honda accord v6 transmission problem
Hi, I have a 2000 honda accord the has a delay in shifting from 1st to 2nd gear and if I step on it will hang on until I let of the gas.
Old Jun 29, 2018 | 12:28 AM
slowcivic2k's Avatar
Default Re: 00 honda accord v6 transmission problem
This is a typical problem with the B7XA transmissions. The clutch pressure control valves in the valve body can leak fluid and cause a really weak 2nd gear shift. Your unit will need to be rebuilt based on your description of the problem. There are a few aftermarket kits that replace the spools for clutch pressure control, the 2nd accumulator spring, and also a pilot drill for 1-2 fluid exhaust (highly recommended you do this). The valve body spacer drilling allows the clutch apply fluid to drain faster, and allow the gearshift to feel more positive. The internal cone filters will also have a lot of debris that will affect shift pressure and feel.
The B7XA does have some natural "odd" performance issues. At light throttle, the shift will be premature and "stiffer", which is acceptable performance. If you have over 40% throttle it will wind out to 3200-4000 rpm and shift "lazy". Aftermarket kits correct this behavior.
Changing the fluid at this stage will also certainly result in increased 2nd gear slippage due to the decreased friction of the fluid (suspended clutch material aids in friction).
Old Jun 29, 2018 | 05:40 AM
Thanks for the info,it really help a lot.
Old Jun 30, 2018 | 12:58 AM
holmesnmanny's Avatar
OP, your rebuilder needs the rebuild kit here https://www.rockauto.com/en/catalog/...build+kit,8512
and then the upgrade kit here as well, he needs to use these parts to upgrade so you don't have the same issue you are having again
https://www.rockauto.com/en/catalog/...ement+kit,8532
you can get a new torque converter from Florida Torque Converters
and a filter
https://www.rockauto.com/en/catalog/...ic,filter,8600
Old Jun 30, 2018 | 06:27 AM
I'm doing the rebuild myself in my home garage.
Old Jun 30, 2018 | 03:07 PM
awesome, Hiram Gutierrez has a lot of great vids on youtube and even one on your transmission so you have a lot of resources
Old May 7, 2024 | 06:01 PM
Pmxney's Avatar
Icon4 2000 Honda Transmission Problems?
Hello, in need of some help. Ive recently started to experience problems with my transmission. It only goes into two gears and will not go into reverse. Whenever in reverse and sometimes parked it will make a grinding noise, not sure why. As well whenever I start it up I can't drive in D4 anymore, so I manual shift it but it'll only go into 2 gears, 1st to start and drive then I can change to 2nd but it still stays as if 2nd isn't there. Then I can't shift to 3rd gear, however it won't accelerate but at a very slow speed and has high rpms while on the gas. Then you can shift it to 4th and it doesn't go anywhere, as if there's no 4th. Question is though why reverse and park make a grinding noise under the hood, and why am I only have two gears and not very good performance. Need some help though because I want to take it on long trips, just not sure how she'll do with these problems. Thank you!
j894
Jun 13, 2020 11:47 AM
Heustoke
Feb 20, 2016 08:11 PM
luismSr
Sep 15, 2014 05:58 PM
sporter20
Feb 17, 2014 12:09 AM
