Want to Turbo JDM H22A
If you want to boost your stock block will handle up to 300hp with good tune. Dont cheap out the parts. You will need turbocharger,manifold,wastegate,bov,bigger injectors,downpipe, intercooler and piping .run 3" exhaust.
Start reading OP. The forced induction section on this site has a wealth of information that will cover most of the basics and some more advanced topics that you should start reading before you buy the first part. 350whp is generally considered the "safe" upper limit with a proper tune and quality parts on a stock engine. Some engines will tolerate more but it's a gamble after that point and reliability goes out the window. The tune will ultimately be the deciding factor. Keeping detonation out of a stock block H series is paramount because if they experience even a brief period of knock the pistons will fall apart.
