Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda civic 04 water leak
Old Jun 12, 2018 | 08:39 PM
Tamer_n_t's Avatar
Default Honda civic 04 water leak
Hi,
I used blue divel for my civic 04 because it was overflow from expansion tank, 3 month later I had saver leak from water pump side, the next day i took it to mechanic to check it, but it stop leak suddenly with no heat. 3 days now.
How could I know what's wrong?
thank you in advance
Old Jun 13, 2018 | 09:11 AM
thisguyaves's Avatar
Default Re: Honda civic 04 water leak
I don't know why this is so hard to understand...
What I think you're saying is that the coolant tank was empty so you filled it and now it's randomly leaking from the water pump? But the water pump is inside the timing belt cover, not sure how you would be able to verify that.
Replace water pump gasket, flush coolant is my recommendation, if I got that right.
justint7121
Nov 21, 2010 09:46 PM
wedtm
Mar 26, 2008 07:59 PM
mike0503
Jul 11, 2007 04:54 PM
Mrob91GS
Mar 26, 2005 08:25 AM
intezn
Apr 4, 2003 09:20 AM
