Rattle Can paint job
Old Jun 12, 2018 | 05:10 AM
AllMtrRex's Avatar
Default Rattle Can paint job
Sharing my rattle can paint Job. This was done in an old horse barn with plastic on the ceiling and walls but not the floor. lol. We got lazy. Project car is a Flamenco Black Pearl, 2000 Civic Si.
Supplies:
Painters tape
Plastic
Roll paper
Local Sherwin Williams mixed me up 3 12oz cans of NH-592P at $30 each
1 12oz can of rust-oleum etching primer
1 12oz can of rust-oelum primer sealer
1 can of spray max 2k clear
Prepped the bay with a few Maroon scotch bright pads (400 grit), I sanded down to the OEM sealer/primer. Followed with 800 grit dry to smooth any roughness.
Sprayed 1 can of etching primer. This was mainly to cover areas where I went down to the bare metal. knocked off some rough areas with 800 grit.
Sprayed 1 can of primer sealer and then followed with 800 grit again.
Sprayed 3 cans of base-coat
Allowing 10-15 minutes of flash time between each can. I used 1 can for 1 coat. The base-coat goes on light
Didn't have time to clear the same day. I cleared the next day (1 can of spray max 2k) after wiping the entire bay with tack cloths and oil and grease remover.
Overall happy with the results. I wanted a clean original look with some pop. Of course there is orange peel. Spray cans produce horrible over spray. However, the orange peel isn't bad at all. I plan to hit the clear with wet 800, 1000, 1500, 2000 and then cut and buff. Should finish this project up. You cant see it in the pictures but there is tons of flake in NH-592P. These pictures were took with 1 overhead LED light. In the sun, this bay will shine like new money!
Old Jun 12, 2018 | 07:51 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Rattle Can paint job
Not bad for an engine bay. Why didn't you fill up the unused holes??
Old Jun 12, 2018 | 09:03 AM
AllMtrRex's Avatar
Going back OEM with everything. So there will not be many holes unused.
Old Jun 16, 2018 | 04:09 PM
2fat2furious's Avatar
Looks like horse **** ...
Old Jun 18, 2018 | 04:03 AM
AllMtrRex's Avatar
I was aiming for dog **** look but i'll take horse ****.
Old Jul 9, 2018 | 07:20 AM
Siouxbie's Avatar
Thanks for the write up with the pics!
Old Aug 6, 2018 | 10:19 PM
ekimnart's Avatar
Look great for spray can. Nice job
MSchu
Paint and Body
Nov 2, 2008 04:16 PM
dagle
Paint and Body
Apr 26, 2008 11:17 PM
EK_B
Paint and Body
Apr 23, 2008 02:21 PM
cilvia
Nov 11, 2006 11:34 AM
Rydaddy
Jul 21, 2003 12:06 PM
