Flat Black Spray Paint....
Old Apr 22, 2008 | 08:58 AM
EK_B's Avatar
Default Flat Black Spray Paint....
If I get it on paint with clear coat, how would I remove it? Also once the flat black is removed, would the paint underneath be damaged?
Old Apr 22, 2008 | 09:54 AM
GriFFIthS's Avatar
if the paint you want removed in on your existing clear coat, take a very fine grit sand paper, maybe a 1000 depending on how think the paint you want gone is, and sand it down slowly and very carefully till the paint is gone removing as little as possible of your clear, then take some 2000 grit and wet sand the area and finish it off with a polish of the clear to bring its finish back.
Old Apr 22, 2008 | 08:03 PM
EK_B's Avatar
So 1,000 grit shouldn't hurt the paint underneath the spray paint?
Old Apr 23, 2008 | 08:55 AM
GriFFIthS's Avatar
not as long as your very carefull and not using to much force, be very light with it, take your time it'll be worth it when its gone and you have minimal clear coat damage, then finish with a 2000 wet sand, clean and polish.
Old Apr 23, 2008 | 02:21 PM
EK_B's Avatar
Okay, thanks. Just asking just in case I get mess up painting.
raider1qaz
Paint and Body
Oct 18, 2013 04:01 PM
EM1 Resto
Paint and Body
Feb 24, 2010 01:03 PM
5Point7Liter
Paint and Body
Jan 10, 2009 06:24 AM
dagle
Paint and Body
Apr 26, 2008 11:17 PM
Rydaddy
Jul 21, 2003 12:06 PM
