swapped civic hard start after fuel fill up
Old Jun 11, 2018 | 03:49 PM
eddie7978's Avatar
Default swapped civic hard start after fuel fill up
2000 civic dx just swapped a b18c jdm type r motor
every time i get gas and try to start it.. it starts and dies immeadeatly .. the second time i try to start it it struggles with an extended crank but it starts
im pretty sure it has to do with the evap system.. i have a picture of how i hooked it up.. .. i’m using the stock jdm p73 ecu.. the motor is obd2a but it uses an obd1 style emissions .. no purge valve.. i put a hose from the throttle body to the canister..
now in the pic where i put it on the canister is where the stock motor purge valve goes..
. just like how it’s setup on an obd1 car.. but maby it is affecting somthing
Old Jun 11, 2018 | 04:56 PM
mk378's Avatar
Default Re: swapped civic hard start after fuel fill up
The canister purge needs to be closed off for starting / idling. I think you can connect the OBDII style valve to an OBD1 ECU. For testing, you can close it off all the time, though that will eventually cause gas vapors to appear under the hood.
It may not be that though. Try clicking the key on several times without cranking to prime the lines.
Old Jun 11, 2018 | 05:25 PM
eddie7978's Avatar
thanks for the reply.. maby i should post it in the hybrid section .. the jdm ecu doesn’t look for a purge valve so my harness for the purge valve is not connected to anything.. my car starts fine any other time just after i get gas.. i’m pretty sure it has somthing to do with the evap system but idk.. the nipple on the throttle body i just hooked it up to the canister is there any other options to try?
Old Jun 12, 2018 | 04:29 AM
eddie7978's Avatar
ok so i talked to a master mechanic he said it’s because i don’t have a purge valve so all the fumes are getting trapped and going to the intake and creating a rich condition.. he said to put a purge valve even tho it won’t function or cap them both off and see what happens
Old Jun 14, 2018 | 03:42 PM
eddie7978's Avatar
i know it has to do with the evap purge system someone has to know
Old Jun 14, 2018 | 05:49 PM
mk378's Avatar
Next time you need to fill up, put a clamp on the hose to pinch it shut before filling and trying to start. If it still doesn't start easily, it's not that. If it does, just take the clamp off once started.
Old Jun 20, 2018 | 01:05 PM
eddie7978's Avatar
is it safe to cap off he canister where thenourge valve hose goes on?? or do i just leave it open??
4drteg54321
Dec 24, 2008 08:01 AM
UCNTCME
Mar 28, 2008 01:31 PM
Keith
Feb 4, 2008 07:56 PM
Turbo_Mike
Mar 31, 2007 03:09 PM
twankies
Feb 13, 2004 06:52 PM
