New Member 94 civic 1.5 l mil dtc 8 HELP
Old Jun 10, 2018 | 07:22 PM
Johnny Thunder's Avatar
Default New Member 94 civic 1.5 l mil dtc 8 HELP
Failed smog
check ignition timing mil/cel dtc 8
OBD systems check
Fuel Evap controls function
The vehicle failed the OBD system check because the MIL was on
Please advise
Old Jun 10, 2018 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: New Member 94 civic 1.5 l mil dtc 8 HELP
Check your distributor wiring... all plugs/pins pushed in tight and no broken or frayed wires. If all appears good... replace the distributor housing.
Old Jun 12, 2018 | 08:21 PM
I replaced the distributor already due to the bearing being bad and new cap/rotor plus wires.
Wiring is all good and connections as well
Old Jun 12, 2018 | 09:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Where did you purchase the distributor from and what brand is it ???
preludepower01
Sep 3, 2007 08:07 AM
rhdjdmda6
Jul 13, 2006 04:52 AM
XstouterX
Feb 28, 2006 07:39 PM
civicboisi
Oct 4, 2004 08:27 AM
Brian_92GSR
May 21, 2002 04:46 PM
