2002 Honda Civic ex oil leak
Check out the 3 Vtec seals, valve cover gasket, and intake manifold seals as well as the rear cam plug. If its not obvious where it's coming from, then clean off the engine with a power washer or brake clean and rags, let dry, and spray the entire engine (including the back by the intake and from underneath) with athletes foot powder spray (I used 2 cans). For added security, I did an oil change and used Engine Oil UV Dye. Run the car for a while and use a UV light to see where the leak is coming from. The powder plus the UV dye might be overkill, but I didn't want to have to do it again (which is my current problem).
Hope this helps, and good luck!
Civichatch972
30
Feb 6, 2009 11:47 AM
