B16b swap, keeping ac/ps which crank pulley?
Old Jun 9, 2018 | 06:45 AM
hybridnorth's Avatar
Default B16b swap, keeping ac/ps which crank pulley?
Hey HT,
It's been years since I've been on the site, getting back into the Honda game. I have a 99 Civic that I am dropping a B16b into. I want to keep power steering and a/c. Which crank pulley do I need to get? 94-97 Del Sol w/ b16 or 99-00 SI b16 or ITR?
TIA
Old Jun 9, 2018 | 07:05 AM
Feriohhh's Avatar
5 Year Member
Default Re: B16b swap, keeping ac/ps which crank pulley?
Del Sol VTEC and Civic Si use the same pulley and each Integra has their own: LS, GS-R and Type R. I've swapped lots of pulleys over the years when piecing swaps together and it never made any difference where they came from so long as they're B-series. Just makes finding belts more of a measurement game than buying strictly on part number. For continuity, if you're buying new, I'd go with the P73 USDM Integra Type R pulley, which is still available new for under 200 from Honda.
Old Jun 9, 2018 | 07:49 AM
Thanks Feriohh, I've read with the mixing of different mounts and pullies etc the belts can be off by an inch. I'll measure with string before I buy.
Old Jun 17, 2018 | 01:58 PM
Update:
The CRV pulley P7J will work, if you are keeping the d-series ac compressor. Also being a B16b I was able to keep power steering without modifying the lower mount.
redline870
12
Feb 15, 2009 05:12 PM
wdelsolo
Oct 22, 2005 11:54 PM
99teggsr
May 13, 2005 12:58 AM
Death_to_Thieves
Feb 19, 2004 01:45 PM
