Honda S2000 Honda S2000
Very strong fuel vapor smell in hot weather
Old Jun 8, 2018 | 05:24 PM
jrlink2k's Avatar
Default Very strong fuel vapor smell in hot weather
Hello,
I have a 2005. With the weather hot in AZ, when the car is parked outside for an extended period of time, after driving for 10 miles or so, and parking, I get an intense gas vapor smell, right around the left rear wheel well.
The evap canister was changed (as the car is not driven often) as was the fuel filler cap. (No codes are thrown, no CEL). I keep speculating what might be the cause: EVAP bypass solenoid valve, EVAP canister vent shut valve, EVAP two way valve, a hairline fracture is the lines...? This happens only in very hot weather. If you have had a similar issue that you managed to solve, I would much appreciate any suggestions.
Many thanks -JR
PS. Had it checked at a dealer to no avail.
Old Jun 8, 2018 | 06:36 PM
MyAcc0rd's Avatar
Default Re: Very strong fuel vapor smell in hot weather
What a shitty dealership. Don't go back to a place that can't figure basic **** out. Two-way valve all day IMHO.
Old Jun 9, 2018 | 06:26 AM
jrlink2k's Avatar
Thanks! Will check the valve.
JR
Old Apr 16, 2019 | 01:36 PM
starbai's Avatar
JR
I'm dealing with the same problem JR, did the valve fix it?
Old Apr 17, 2019 | 07:38 PM
jrlink2k's Avatar
Hi, hard to tell yet, as the temps have been pretty moderate. Will report back in the summer.
Thanks JR
Old Feb 10, 2020 | 05:30 PM
azchris's Avatar
Have you checked the in-tank fuel filter for cracks? (On a 2001 Civic with a similar setup, it's made of plastic and developed spider cracks and leaked fuel along the top of that whole assembly).
See attached photos from a 2001 Civic.
I also live in AZ and the heat destroys everything plastic and rubber. I also get a strong fuel smell on my 95 accord only on hot days when the car is hot but it is nowhere near as bad as it got on the '01 civic with the cracked fuel filter/module cap.
spider cracks in plastic of fuel filter (2001 Civic)
removed from car, was able to replace fuel filter (top portion)
Old Feb 14, 2020 | 03:05 PM
jrlink2k's Avatar
Many thanks, this is very useful! JR
knaup109
Jul 8, 2017 04:01 PM
F20Cdriver
Feb 21, 2015 07:55 PM
justinsbg
Jan 24, 2015 06:51 PM
Cyber ITR
Nov 21, 2004 06:26 PM
Evil DOHC
Sep 24, 2001 04:36 PM
