Back door lock '96 accord wagon
Old Jun 6, 2018 | 12:22 PM
on the wagon's Avatar
Default Back door lock '96 accord wagon
The key used in the back door will lock and unlock the four doors, but the back door remains locked.
Old Jun 10, 2018 | 12:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Back door lock '96 accord wagon
It may be due to a faulty tailgate door lock actuator. The tailgate key cylinder switch is separate from the tailgate door lock actuator.
Unplug Connector C595. Apply direct 12 volt power (+) and ground (-) to the actuator motor wires to see if it operates.
  • Unlock: Power (+) to terminal no. 4 cavity (Yel/Red wire) and Ground (-) to terminal no. 3 cavity (Wht/Red wire) momentarily.
  • Lock: Power (+) to terminal no. 3 cavity (Wht/Red wire) and Ground (-) to terminal no. 4 cavity (Yel/Red wire) momentarily.
Old Apr 4, 2022 | 02:46 PM
GRFMotorsports's Avatar
Has anyone rebuilt one of these. I have mine out, havent been able to find a replacement. When I bench test it the motor turns over but seems very weak. Not enough power to move the lock. The wheel that move the lock arm is spring loaded to a neutral position it would seem. Is this correct? Thanks in advance for any help.
SilverEK96
Audio / Security / Video
Jun 6, 2012 03:54 PM
ryanplayjoint
11
Apr 4, 2011 04:59 PM
Andrewm224
Oct 21, 2005 07:33 PM
216.226.142.95:27016
Dec 12, 2002 07:37 PM
