Lighting HID/Xenon kits, Retrofits and Associated Topics
Running lights not working, 2 months diagnosing and took to shop.
Old Jun 3, 2018 | 05:49 PM
McD6288's Avatar
Default Running lights not working, 2 months diagnosing and took to shop.
Hi, I have a 1989 honda civic hatchback. stock wiring.
Things that work:
Headlights
Turn Signals
Hazards
Reverse
Things that do not work:
all running lights(first click of headlight switch on steering column usually turns these on)
cluster lights
dimmer switch
Dimmer Switch:
Taken apart
found a break in one of the solder joints, re-soldered it, still unresponsive
Checking plug connections
check for voltage from red to black and red/black to black. 0 volts on any setting of headlight switch
check ground for continuity to chassis, has continuity
short from red to black, unresponsive
Headlight Switch(on steering column)
1st one(stock from 89 civic hatchback)
Taken apart
followed video guidance on how to check for breaks, cleaning, and reassembly
gets power to headlights only on 2nd click
no power through on 1st click
2nd one(from 91 crx Si) currently in vehicle
Taken apart
same as 1st
Taken to shop known for working on old EF civic/crx/sedans. owner has 2 RHD, seems to know what he's doing.
Made a jump from RED/GREEN to RED/YELLOW on headlight switch(on steering column)
pic shown
RED/GREEN to RED/YELLOW done by shop.
This worked for a week, then started blowing the 10A fuse for the running lights.
UPDATE: got a new ICU(grey box on the back of the fuse panel) like-new board, no signs of roasting at all.
Nothing has changed.
Old Jun 4, 2018 | 05:34 PM
McD6288's Avatar
Default Re: Running lights not working, 2 months diagnosing and took to shop.
Old Jun 5, 2018 | 04:18 PM
thisguyaves's Avatar
Could you short them at the fuse box and fire the lights that way
McD6288
Jun 4, 2018 05:34 PM
kayONE
Mar 24, 2013 10:27 AM
KCHC
15
Sep 5, 2012 10:00 AM
ek_b16
Jan 3, 2010 09:35 AM
mattjohnston
Sep 10, 2003 04:44 AM
