92 Civic SI won't start after wire tucked
Old Jun 1, 2018 | 02:28 PM
WAUKEENEM1's Avatar
Default 92 Civic SI won't start after wire tucked
Got a 92 Civic SI that wont turned over after wire tucked. Was a running and driving car. I did not do the wire tuck. My buddy said he did
the exact same thing on his eg hatch and it works great.
However, for some reason it just cranks and cranks but won't turned over. I know the ecu, main relay, ignition system works...as I got spark, fuel, timing is also good.
Could it just be a bad ground somewhere? As of now, there is ground on the valve cover, t-stat housing, tranny, and negative battery terminal (battery)which as been moved inside the car, behind the dash.
Also the dash is out if that's got something to do with it. Motor was also taken out to be cleaned and put back on car.
Any tips, help, suggestions would be greatly appreciated.
Old Jun 1, 2018 | 03:20 PM
tony_2018's Avatar
Fish Twig
Default Re: 92 Civic SI won't start after wire tucked
If you bought it from your friend I suggest you have him come back and double check his handy work.
Old Jun 1, 2018 | 03:47 PM
WAUKEENEM1's Avatar
He just helped do the wire tuck. We both check everything that we thought might be the culprit.
Even swap/test parts from a stock driving eg civic.
Old Jun 1, 2018 | 03:53 PM
sirtef99's Avatar
Are all the grounds on, like at the thermostat housing?
Old Jun 1, 2018 | 04:22 PM
WAUKEENEM1's Avatar
The main ones are on, like valve cover, battery, tranny, t-stat housing
headlights n grounds are not connected yest but i dont think that should affect starting though.
Old Jun 1, 2018 | 07:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have missed something. If you have a known good ECU (like it works in another car... like your buddy's), you hear the main relay click and the fuel pump prime when the key is turned on, and you have spark and fuel at each cylinder (plugs are wet since the car won't start), the engine SHOULD RUN !!! So check all of these things again.
Old Jun 1, 2018 | 08:16 PM
WAUKEENEM1's Avatar
Yeah, you would think it should run but the only thing to double check is if the injectors actually fires even though it got fuels to the rail
its got 12v power on the injector wires but ill take the plugs out n clean it
got 3 good p28 ecu...test all of them on the other hatch n its good
Old Jun 4, 2018 | 10:18 AM
da1lydr1ver's Avatar
worth a shot in the dark... but is your gauge cluster plugged in? Not sure on '92-'95 year civics, but i think i heard that on some newer cars, if your gauge cluster isn't plugged in, then the car wont turn over.
Old Jun 4, 2018 | 06:50 PM
WAUKEENEM1's Avatar
Its not plugged in but its worth shot...
Old Jun 9, 2018 | 06:22 AM
WAUKEENEM1's Avatar
Ok...i unplugged the gauge cluster on my beater hatch but car still starts...so my other question is
does the entire dash needs to plug in for car to start?
The dash was removed to do the wire tucked and hvac delete
Old Jun 9, 2018 | 11:21 AM
eat5's Avatar
i put my battery in trunk and grounded it to frame. im tucking wires right now. pain in the ****. every step i do i make sure it works. old harness had alot of cracked plastic on wires causing problems....
Old Jun 9, 2018 | 04:42 PM
WAUKEENEM1's Avatar
Got the car fired up today...it was one of the wire hardness behind the dash...couple wires were frayed so...must shorted or not having good current
B16a2Em1
Mar 17, 2011 08:53 PM
mrmoney232323
Sep 9, 2007 05:31 PM
E36 Guy
11
Jan 19, 2005 07:18 AM
upgraded
Nov 16, 2003 02:59 PM
shipsaeki
Nov 7, 2002 11:48 AM
