Looking for a full build
Later on about September, I should have plenty of money saved up for a Honda Civic Del Sol. Right now I only own a motorcycle. Ok, so I was thinking, I would love to have a del sol with a motor swap using a 4g63 engine and put out around 400-500 whp. I would also like the car to be awd.
So perhaps a shell would be good, then swap and other parts needed bought and installed. I have no idea who could help me around here. I'm in Minnesota. No experience working on cars. I used to own a del sol back in the day.
How much would it be to get a project like that done? At the right time, I will have about 8-9 k to use. hopefully the project will be less, but thats that.
4G swap with AWD in a Honda chassis will easily cost double the price range you're currently looking at, especially if you aren't doing any of the fabrication work yourself.
You're gonna have a bad time. Just get an Evo if you want an AWD 4G63, either that or look into a turbo B Del Sol build while keeping FWD.
OP, are you aware of the quality difference between ANY Honda/Acura engine and a 4G63 engine ??? Funny that this is your first post... and ironic that you joined a Honda Forum to ask about a Mitsubishi engine.
Me thinks thou art a troll... oh, and welcome to the board.
And the 4G63 is still a pretty amazing engine. Cylinder heads don't flow on par with B/K/H/F engines, but as long as you don't get one of the older 4G engines with the dreaded crank walk problem, they're pretty solid.
Del sol shell 500-1000, used 4G63 engine and tranny 1500-1800, to have a shop fully build it 2000-3500 just for the block/ crank/ pistions etc, more if you want head work. Then labor for a custom install of a different brand engine you are looking at 3 to 4k in labor alone then cutom fabrication for AWD drivetrain could be thousands more. Then turbo setup, intercooler, custom piping, custom exhaust etc probably 5-6k easy in parts and labor. Then professional dyno tuning 300-700. Even for a shop with good rates you are looking at 15k bare minimum man, probably closer to 20 when you factor unknown issues.
wow, 20 large for something like that. I'll probably go ahead and get something already built. I'm sure there would be a nice car out there for no more then 10g. Honestly, I'm looking for certain imports, most from 1990-1999. 300zx is in the running. MR2 in the running. Trying to brain storm what it is that I think I would like, or a way to get there.
Lol one post wonders, am I right?
Going through the trouble of swapping a 4g63 into a honda, instead of just buying an eclipse or easily building a honda engine to 500whp is one of the dumbest things I have read all week.
If you need a 4g63 and awd, just buy a gsx eclipse and be done with it....
Someone working at my local Lowe's has the cleanest first gen eagle talon I have ever seen. I am not sure if its fwd or awd, but it is definitely the turbo model and extremely stock. It gets me running major life decisions in my head every time I see it. It would be so low key/under the radar here (central florida is dominated by orlando fiebre civic **** boxes. no one would bat an eye at a clean dsm) and would make an awesome sleeper.
Can buy mid 2000s (years) MazdaSpeed (turbo) 6 AWD for cheap.
https://www.google.com/amp/s/www.car...drive-review-1
nothing wrong with someone wanting to do something different. Thats always been my passion. When i first started getting into imports it was still the laughable times when 300hp was big numbers and we were happy when we beat a stock gt mustang or stayed fender to fender with a stock corvette. Being realistic in the budget is one thing, but shooting someone down just for doing something different isnt cool.
Sleepr DSM
Feb 8, 2018 06:57 PM
xx7xx
22
Nov 25, 2008 04:49 PM
