So I am gathering the necessary parts for my b swap. The swap came with an integral pump on it. My parts car a 97 ex had this power steering line (top fitting in picture) and Integra line is lower fitting. By the looks of the rack end the Civic and Integra lines are different. Does the line I took from my ex look like it's going to work with the Integra pump?
Reason: Pic
Of course the lines are different where they bolt to the rack. The hard line fitting at the P/S pump end appears to be the same. There are only TWO different versions: The large diameter "centerline" style fitting and the small diameter "offset" style fitting. You have the large diameter "centerline" style fitting... and the P/S pump you got with your swap has the same style. Bolt it up... it will work.
