ABS delete need help!
Hi on my 96 civic ek4 I’ve done a abs delete with a 40/40 prop valve and full braided line ran through the inside of the car. My issue is that when I press the brake pedal the brakes only work very slightly when pressed hard. I’m unsure of wether I need a master cylinder from a non abs Model or will my standard one work fine ? It’s such a simple job but I’m really struggling to get this to work so any help appreciated! Cheers
Yeah I believe so every thing I’ve seen online I believe it all to be done properly. Does the ports on the master cylinder matter what way round the go to the prop valve ?
xBoosted4drx
May 3, 2005 10:39 AM
