Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Honda Accord 4 cyclinder AC Clutch not Engaging
Old May 24, 2018 | 09:17 AM
dannydarkman's Avatar
Default 2007 Honda Accord 4 cyclinder AC Clutch not Engaging
Hi, I have a 2007 Honda Accord 4cyclinder 4 door. I replaced the relay and the clutch does not want to engage. It does however engage when I jump it. As well, my blower motor resistor sent bad so I jumped that temporarily so it’s only blowing max air. Would that effect the clutch not to engage. The freon level is good, but when I jump the relay for the clutch to engage, I’m not getting very cold air. Any suggestions would be much appreciated! Thanks!
Old May 26, 2018 | 11:38 AM
Crimson Jax's Avatar
Default Re: 2007 Honda Accord 4 cyclinder AC Clutch not Engaging
I'm having the exact same problem. Relays and fuses are good but clutch won't engage. If you don't mind me asking, which wire did you jump to check if the clutch would engage. I only see 2 black wires going to the compressor.
Old May 26, 2018 | 05:26 PM
holmesnmanny's Avatar
its likely you dont have enough refrigerant, which would mean a leak
Old May 26, 2018 | 06:48 PM
It was the relay for mine. I switched out the rad fan relay to test it and the clutch engaged. I got a new relay and mine is working again. Thanks
Old May 26, 2018 | 07:06 PM
Hey Crimson. When you are standing facing the car, use a paper clip or wire to jump the top two relay slots that controls the compression slot. You should hear the engage click on even without any power.
I verified by engaging the compression clutch mentioned above and turned the car on. I was getting cold air. From talking to a mechanic buddy of mine, it looks like it could be the module not sending the signal.
Old May 26, 2018 | 11:02 PM
which statement is correct ?
Old May 27, 2018 | 06:27 AM
Haha... Both are correct. Still getting cold but just not freezing cold like how I would like it. Regardless, there is enough freon. I verified with a pressure hookup at my buddies garage.
nirvana_1959
Honda CR-V & Element
Apr 30, 2018 03:55 PM
orgchm
Aug 10, 2015 12:07 PM
lunkerv16
Aug 1, 2008 05:02 AM
oranginal
Jun 16, 2007 07:39 PM
