Codes p2646,pp0301
Codes p2646,pp0301
2005 accord 2.4 eng. Im getting p2646 vvt code and p0301 misfire code cylinder #1.
codes.history of this issue is i got both codes and solid dash light and flashing dash light (eng light).
At speeds between 45-65 it will flash. So i changed the vvt actuator spool on rear of engine. And p2646 code cleared.( or so i thought) next i changed spark plugs and did the coil unplug test and engine studdered with each coil, i also switched coil positions unhooked battery to clear codes and drove car. Light stayed off for 20 miles then flashed and stayed on i changed fuel injectors. so now after 2 weeks the car is giving the p2646 and after hits operating temp will not go over 3000 rpm unless you ahut off key then it drives correct for a way then goes back to not going over 3000 rpm.. So at moment it has eng liight on with p2646 and p0301 codes..I truly need some help
UpstateCivic
06-07-2003 12:27 PM
