Question about rechipping a ecu
Old Nov 12, 2002 | 05:04 PM
fire7882's Avatar
Default Question about rechipping a ecu
I have a p06 ecu laying around so i decided to try my hands at chipping it. I can't even get started because i can't get the solder out of the holes where the eprom socket is going to go. When i heat it up and melt it, it won't fall out of the hole and pushing it out with a wire dosn't seem to help either. I just end up soldering that wire in. I know this must seem like a noob question but i want to learn. Please help me.
Old Nov 12, 2002 | 08:15 PM
Kataku2K3's Avatar
Default Re: Question about rechipping a ecu (fire7882)
When I chip ECU's i just use desoldering braid... It's just a copper braid that soaks up solder like crazy... If that doesn't work try a solder sucker.. Once you get it all out just carefully lift out the ROM... Latez
Old Nov 12, 2002 | 08:24 PM
fire7882's Avatar
Default Re: Question about rechipping a ecu (JDMspecEG6)
Thanks, i never knew of such. Soldering is new to me but i figured i would give it a try.
dornon13
Aug 13, 2004 12:55 AM
AndyD
Jun 3, 2004 04:38 AM
typeR#0427
Jun 9, 2003 03:47 PM
