My em1 build thread
Old May 20, 2018 | 09:09 AM
nutz4vette's Avatar
Default My em1 build thread
Traded an 07 civic lx coupe in great condition for this, trade way down but had to save this car and didn’t need the 07 anymore
The day I picked her up
Nasty
So much eBay
Last edited by toyomatt84; May 20, 2018 at 09:24 AM. Reason: Removed Craigslist ad.
Old May 20, 2018 | 11:38 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: My em1 build thread
what are your plans?
Old May 20, 2018 | 12:01 PM
nutz4vette's Avatar
basically had the car about a year and a half now, swapped it with a usdm b18c5, did all suspension, was building it for auto x but spun a rod bearing last August, been rebuilding it turbo since then, block is done, Head is with my tuner atm, and already piecing my turbo setup together now, I’ll be posting everything step by step up to current soon
Old May 20, 2018 | 01:08 PM
Feriohhh's Avatar
5 Year Member
Oof. That poor civic.
Old May 20, 2018 | 01:51 PM
nutz4vette's Avatar
So far
Block mods:
B18c5
Eagle rods
Wiesco 9.6:1 pistons
Acl main bearings
King rod bearings
Ati super street damper
New oem water pump
New oem oil pump
New oem gaskets and sensors
Arp head studs
Innovative 80a mounts
Hasport torque mounts
Head mods:
B18c5
Supertech valve guides
Ferrea 6000 intake valves
Ferrea comp plus exhaust valves
New oem valve seals
Sk2 pro series dual valve springs
Sk2 ti retainers
Sk2 Lmas
Sk2 pro 1+ Cams
Sk2 cam gears
Bdl fuel rail
Hondata intake mani gasket
Trans mods:
B18c5
Comp stage 4 6 puck unsprung kit
Russell ss clutch line
Exedy master and slave cylinder kit
Suspension mods:
Progress cs2 coilovers
Function7 rear lcas
Sk2 lca hardware
Hardrace upper control arms front and rear
Hardrace trailing arm bushings
Hardrace rear toe kit
Asr rear brace 24mm sway bar kit
Spoon front and rear sway bars (legit)
Buddy club ball joints
Insane shaft 500hp axles
New Koyo wheel bearings all around
Misc mods:
Ktellar 3” mandrel exhaust
Vibrant turbo muffler and resonator
Mishimoto radiator, fan, and hoses
Chipped p28 on neptune
Buddyclub p1 wheels (white)
205/50/15 nitto neo gen tires
Optima yellow top battery
B&Mshort throw
Old May 20, 2018 | 02:02 PM
nutz4vette's Avatar
Future mods:
Garrett Gtx3582r with tial v band housing
Sheepey a/c compatible t3 top mount manifold
sheepey 850hp intercooler
sheepey catch can(have)
Custom downpipe
Custom intercooler piping
turbosmart 45mm hypergate (have)
tial Q 50mm bov (have)
jbtuned full e85 kit
Walbro 450lph pump
injector dynamics 1300cc injectors
Aeromotive fpr(have)
omni 4 bar map (have)
Aem Air/fuel and boost gauge (have)
Defi water temp, oil press, and egt gauges
and of course a retune
Old May 20, 2018 | 02:50 PM
nutz4vette's Avatar
Old May 20, 2018 | 03:40 PM
toyomatt84's Avatar
Sanji
Relax with the repeat posts, bud. Your pictures were flagged as unapproved, so a staff member had to approve the posts. Its a setting we have no control over, sadly.
Old May 20, 2018 | 03:55 PM
nutz4vette's Avatar
It’s all good, sorry, thought it was a problem on my end
Old May 20, 2018 | 04:05 PM
nutz4vette's Avatar
Wheels and suspension
Old May 22, 2018 | 06:25 AM
SonicC's Avatar
moAr!!!
:D
Old May 22, 2018 | 06:20 PM
Freedo_Civegra's Avatar
Thank goodness you rescued it! Do the bolt heads on those UCA’s hit the fender well?
Old May 22, 2018 | 08:47 PM
nutz4vette's Avatar
Nope, all good
Old May 23, 2018 | 10:51 AM
nagami's Avatar
sub'd to this thread
Old May 24, 2018 | 03:20 AM
nutz4vette's Avatar
Just wanted to show some of the treatment I saved the car from, this car did have high mileage from what I understand but every single panel on the car was straight and matching number, and even the motor and trans vin matched, but the exhaust was rusted in half, break pads worn down to nothing, every single suspension bushing worn out, ball joints sway bar links and tie rod ends worn out, all 4 ball joints
completely shot, had eBay rear camber kit but was only held on the body side by one bolt on both sides and they were loose, and then there is the subs everywhere, I still have to get and weld in a rear panel, and he ruined the doors completely
Old May 24, 2018 | 03:22 AM
nutz4vette's Avatar
I have fixed everything mentioned above accept where the speakers were, I have doors but they are black so won’t be put on the car until i respect the whole car, and same for the panel under the window
Old May 24, 2018 | 06:30 AM
Dang! Forget I said rescued: you straight up brought redemption to that thing.
Old Jun 7, 2018 | 11:24 AM
nutz4vette's Avatar
Old Jun 8, 2018 | 04:56 AM
Turbo time!
Old Jun 8, 2018 | 05:26 AM
CandyRedRC46's Avatar
Engine build specs please.
Old Jun 8, 2018 | 03:47 PM
nutz4vette's Avatar
Everything done to the car is listed above but in a nutshell, b18c5 with wiesco pistons at 9.6:1 compression and eagle rods stock sleeves, Head is getting redone at the moment with new Supertech valve guides, Ferrea 6000 intake and comp plus exhaust valves, fresh valve job and new oem seals, Skunk2 valve springs, ti retainers, lmas, pro cam gears, and swapping my pro1 cams for tuner1 cams, the turbo is pte 5858 and probably gonna do a speedfactory a/c comparable ramhorn
Old Jun 11, 2018 | 06:14 AM
I was hoping for more specific details, anyways, why the down grade from pro1 to tuner1?
Old Jun 18, 2018 | 12:41 AM
nutz4vette's Avatar
My list up top is as specific as it gets, literally everything done to the car, and I am going to tuners over pros Because I am going to be running a 5858 turbo and the pro 1+ require a 62 mm turbo or bigger which is way overkill and way too laggy for what I’m building seeing as how I only am shooting for 500 hp The original goal was to build everything to support way more horsepower when I got my forged block done but now I’m just going to have it at 500 probably for good even with sleeved block later
Old Jun 18, 2018 | 12:42 AM
nutz4vette's Avatar
I meant sleeved block, my current one has forged internals but stock sleeves, night shift got me not thinking straight lol
Old Jun 18, 2018 | 12:49 AM
nutz4vette's Avatar
I have however change the turbo set up that I have in mind I purchased a 5858 from here and now looking at a KLM or speedfactory AC compatible ramhorn manifold instead of a topmount and GT35r
