My em1 build thread
Traded an 07 civic lx coupe in great condition for this, trade way down but had to save this car and didn’t need the 07 anymore https://cimg4.ibsrv.net/gimg/honda-t...8d596fdcc.jpeg The day I picked her up https://cimg6.ibsrv.net/gimg/honda-t...2aa7bbcb3.jpeg Nasty https://cimg5.ibsrv.net/gimg/honda-t...23046cb02.jpeg So much eBay |
Re: My em1 build thread
what are your plans?
basically had the car about a year and a half now, swapped it with a usdm b18c5, did all suspension, was building it for auto x but spun a rod bearing last August, been rebuilding it turbo since then, block is done, Head is with my tuner atm, and already piecing my turbo setup together now, I’ll be posting everything step by step up to current soon
Oof. That poor civic.
So far Block mods: B18c5 Eagle rods Wiesco 9.6:1 pistons Acl main bearings King rod bearings Ati super street damper New oem water pump New oem oil pump New oem gaskets and sensors Arp head studs Innovative 80a mounts Hasport torque mounts Head mods: B18c5 Supertech valve guides Ferrea 6000 intake valves Ferrea comp plus exhaust valves New oem valve seals Sk2 pro series dual valve springs Sk2 ti retainers Sk2 Lmas Sk2 pro 1+ Cams Sk2 cam gears Bdl fuel rail Hondata intake mani gasket Trans mods: B18c5 Comp stage 4 6 puck unsprung kit Russell ss clutch line Exedy master and slave cylinder kit Suspension mods: Progress cs2 coilovers Function7 rear lcas Sk2 lca hardware Hardrace upper control arms front and rear Hardrace trailing arm bushings Hardrace rear toe kit Asr rear brace 24mm sway bar kit Spoon front and rear sway bars (legit) Buddy club ball joints Insane shaft 500hp axles New Koyo wheel bearings all around Misc mods: Ktellar 3” mandrel exhaust Vibrant turbo muffler and resonator Mishimoto radiator, fan, and hoses Chipped p28 on neptune Buddyclub p1 wheels (white) 205/50/15 nitto neo gen tires Optima yellow top battery B&Mshort throw |
Future mods: Garrett Gtx3582r with tial v band housing Sheepey a/c compatible t3 top mount manifold sheepey 850hp intercooler sheepey catch can(have) Custom downpipe Custom intercooler piping turbosmart 45mm hypergate (have) tial Q 50mm bov (have) jbtuned full e85 kit Walbro 450lph pump injector dynamics 1300cc injectors Aeromotive fpr(have) omni 4 bar map (have) Aem Air/fuel and boost gauge (have) Defi water temp, oil press, and egt gauges and of course a retune |
Relax with the repeat posts, bud. Your pictures were flagged as unapproved, so a staff member had to approve the posts. Its a setting we have no control over, sadly.
It’s all good, sorry, thought it was a problem on my end |
moAr!!!
:D |
Thank goodness you rescued it! Do the bolt heads on those UCA’s hit the fender well? |
Nope, all good |
sub'd to this threadhttp://gshort.click/isna/4/o.png
Just wanted to show some of the treatment I saved the car from, this car did have high mileage from what I understand but every single panel on the car was straight and matching number, and even the motor and trans vin matched, but the exhaust was rusted in half, break pads worn down to nothing, every single suspension bushing worn out, ball joints sway bar links and tie rod ends worn out, all 4 ball joints https://cimg5.ibsrv.net/gimg/honda-t...fbd8168b5.jpeg https://cimg3.ibsrv.net/gimg/honda-t...375a68d58.jpeg https://cimg4.ibsrv.net/gimg/honda-t...984e5efed.jpeg https://cimg6.ibsrv.net/gimg/honda-t...a4896d1ef.jpeg https://cimg7.ibsrv.net/gimg/honda-t...4cd709ef1.jpeg completely shot, had eBay rear camber kit but was only held on the body side by one bolt on both sides and they were loose, and then there is the subs everywhere, I still have to get and weld in a rear panel, and he ruined the doors completely |
I have fixed everything mentioned above accept where the speakers were, I have doors but they are black so won’t be put on the car until i respect the whole car, and same for the panel under the window |
Dang! Forget I said rescued: you straight up brought redemption to that thing. |
Turbo time! |
Engine build specs please.
Everything done to the car is listed above but in a nutshell, b18c5 with wiesco pistons at 9.6:1 compression and eagle rods stock sleeves, Head is getting redone at the moment with new Supertech valve guides, Ferrea 6000 intake and comp plus exhaust valves, fresh valve job and new oem seals, Skunk2 valve springs, ti retainers, lmas, pro cam gears, and swapping my pro1 cams for tuner1 cams, the turbo is pte 5858 and probably gonna do a speedfactory a/c comparable ramhorn |
I was hoping for more specific details, anyways, why the down grade from pro1 to tuner1?
My list up top is as specific as it gets, literally everything done to the car, and I am going to tuners over pros Because I am going to be running a 5858 turbo and the pro 1+ require a 62 mm turbo or bigger which is way overkill and way too laggy for what I’m building seeing as how I only am shooting for 500 hp The original goal was to build everything to support way more horsepower when I got my forged block done but now I’m just going to have it at 500 probably for good even with sleeved block later |
I meant sleeved block, my current one has forged internals but stock sleeves, night shift got me not thinking straight lol |
I have however change the turbo set up that I have in mind I purchased a 5858 from here and now looking at a KLM or speedfactory AC compatible ramhorn manifold instead of a topmount and GT35r |
