Clutch adjustment
Old Nov 12, 2002 | 04:18 PM
Brett's Avatar
Default Clutch adjustment
Since I've bought my gsr and driven it hard the clutch has slowly started to bite higher up in the range. It used to grab way down by the floor and now it doesn't grab until it's almost completely let out. Do I just need a new clutch or is there anything I can adjust?
Old Nov 12, 2002 | 04:45 PM
SupaTegRS's Avatar
Default Re: Clutch adjustment (Brett)
mine does this too, it only bites when the clutch pedal is completely out....I'm having trouble shifting into 1st and second every once in a while. I think my clutch is going out, but i dunno if where the clutch is biting on the pedal stroke has anything to do with it.
Old Nov 12, 2002 | 05:43 PM
Brett's Avatar
Default Re: Clutch adjustment (SupaTegRS)
I forgot to say it's a 97 gsr.
Old Nov 12, 2002 | 07:59 PM
superfuji57's Avatar
Friction point?
Old Nov 14, 2002 | 09:24 PM
Brett's Avatar
Default Re: Clutch adjustment (superfuji57)
what is the friction point?
Old Nov 15, 2002 | 01:18 AM
RSvtec's Avatar
friction point is where the clutch starts to grab the flywheel and pressure plate.....hope that helps..............and i think ur clucth is going bad cuz mine did that on a exedy clutch and when i replace it the clutch didnt have the pads anymore. lastly concerning clutch adjusment theres very little play with the pushrod so no matter what u do there will be minimal play on the pedal play
meece0927
Jul 2, 2013 08:15 AM
InitialJRift
Sep 13, 2006 10:43 AM
xunkn0vvnx
Mar 9, 2005 01:47 AM
MachAF
Mar 14, 2003 03:46 PM
