distributor part
Just be aware that proper installation, of a replacement cam cap/guide/holder requires a specific calibration called line honing.
Begin researching how to measure the final space, between the cam shaft and this cam holder, with Plastigauge.
Make sure you get the correct thickness of plastigauge and test torque it.
If your measurements are within tolerance, no line hone is needed.
I had a high hit that broke my valve cover and one of its posts. The post threaded in to the cam holder, at 9 ft/lbs.
I had my cam holder welded, instead of replacing it and going thru the hone alignment.
The damage is circled in red, below.
yeah probably I just get mine welded to if it is that hard to replace it then but how much do u want for though,?
