Honda CR-V & Element 2WD & 4WD Element & CR-V
05 CRV “N/A” Codes?
Old May 14, 2018 | 12:37 PM
CRV05's Avatar
Default 05 CRV “N/A” Codes?
2005 CRV has maintenance light and has for a while. Read it with OBD and got 1 code: “N/A”. Checked the list of things that were ready/not ready and ended up finding: EGR, HCM, 2AIR and A/C were all “N/A” instead of “Ready”. What do these 4 things mean and why are they showing up as N/A? Thank you!
Old May 15, 2018 | 04:47 AM
ThisIsMatt's Avatar
Default Re: 05 CRV “N/A” Codes?
If it's your "maintenance light" and not your "check engine light" that's on, then you won't get any DTCs (diagnostic trouble codes) because the maintenance light only turns on when you have service work due (30k, 60k, 75k services etc...). It's triggered by mileage and reminds you that you have preventative maintenance due. The check engine light is what lights when you have some sort of emissions system failure.
TommyEp3
Jun 4, 2013 12:14 PM
BiggieBert
Acura TL, RL & ZDX
Sep 20, 2008 08:59 AM
Corruption
Jun 3, 2006 12:08 PM
VTECVillain
Jan 6, 2002 11:40 AM
under_psi
Aug 16, 2001 12:50 PM
