00 Si Motor , I got Questions???
is the Crank Flucuation Sensor the same as the Crank Angle Sensor?
On a 00 Si motor where and what does the Evap Purge Solenoid look like??
Thanks Guys in Advance
On OBD2 motors in the distributor you still have the same sensors, CKP, CYP, and TDC.... on the oil pump you also have the crankshaft speed fluctuation sensor.. I don't know which one is being refered two as the crank angle but i would think that you are talkin about the crankshaft position sensor in the distributor.. Again don't take my word for it, as i am not sure which one they are talkin about.. Also OBD2 motors have a different type of purge solenoid.... I'm not perfectly sure on the 2000 Si but you can see it ontop of any of the new integra motors just to double check... It's a little black solenoid with a hose running off of it to the intake manifold and to the purge canister..
You should be able to figure it out..... If not then i'll try to find a pic of a 99-00 Si engine bay to show you exactly where it is
... Latez
... Latez
i found the CKF sensor , but still and stumped on the Evap purge .
Is it mounted on the fuel rail or is that one other sensor also , oh yeha the one on hte fuel rail has a red hose??
That may be it, damn it sucks I can't think right now.... It's above the fuel rail right??? does it connect to a plenum off the top of the manifold?? You know what the PCV system is right because I just don't want you to get all confused.. Good Luck
Spence
10
Apr 24, 2006 09:37 PM
