Honda CR-V & Element 2WD & 4WD Element & CR-V
How to correctly remove the "99 CRV Gen 1 Airbox?
Old May 13, 2018 | 09:29 AM
B20Zer's Avatar
Default How to correctly remove the "99 CRV Gen 1 Airbox?
After you remove the top 2 bolts on the intake airfilter box there's a rubber clip at the bottom, it's very hard to pull off the mount bracket which makes me wonder what is the correct method for getting it off, undo the bolts and take the whole lower bracket off?
If you can just pull it off am I supposed to be pulling it up or sideways?
When I took the airbox out last week only pulling upwards very hard would get it off the post and that also pulled the rubber bush off.
There is a narrow cutout on the airbox mount that attaches to the bracket post, not really enough to pull it off though and from past experience with airboxes they tend to crack quite easily at these rubber mount locations and then the fun starts..
Here's a pic of what I'm referring to:
Lower airbox mount
Old Dec 17, 2022 | 10:58 AM
handrrez's Avatar
Default Re: How to correctly remove the "99 CRV Gen 1 Airbox?
Hi @B20Zer ! Saw your thread and I’m currently scratching my head trying to figure it out! Did you end up finding a solution/approach to this?
Any info/direction would be much appreciated!
White_EG1
Nov 1, 2018 06:17 PM
SIRIUS VTEC
Aug 9, 2010 11:53 PM
Arthas
Jul 23, 2010 01:38 PM
mercutio_07
Mar 19, 2008 04:35 PM
invisible
Feb 11, 2007 05:50 PM
