Do i need rear camber adjuster, alignment ok?
Old May 13, 2018 | 03:48 AM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Default Do i need rear camber adjuster, alignment ok?
Here is my Vehicle Alignment Report after a 4 wheel alignment on my 95 honda civic daily driver street car.
Are the specs right? Did they do a good job? Mechanic said i need adjustable rear camber but i heard these cars don't in most cases. Do i need it? I have adjustable coilovers but car isn't extremely lowered but is lowered maybe an inch with 16" tires.
Old May 13, 2018 | 05:20 AM
tony_2018's Avatar
Fish Twig
Default Re: Do i need rear camber adjuster, alignment ok?
You should try to learn to read that sheet, so you'll understand whats going on. If the alignment shop says you need it then you need it.
Old May 13, 2018 | 06:36 AM
Droop408's Avatar
I can’t read that sheet either. I need to learn too since I’ll be lowering my car soon. Hope someone helps you out.
Old May 13, 2018 | 10:12 AM
tony_2018's Avatar
Fish Twig
Thanks OP for removing the alignment sheet.
Old May 14, 2018 | 01:49 AM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Hey I didn't remove the alignment sheet but some people have said they can't see my pics but idk why.
the mechanic acts like I'll be ok without the adjustable rear cambers but I guess I'll get some.
i can read the data sheet ok it makes it easy because the red numbers are out of spec and i know all the terms under the primary angles, jw if anything looked wrong to y'all besides that.
so i got Hardrace brand rear adjustable camber kit
FreshJr
Feb 14, 2014 06:22 PM
michael-crxsi
14
Nov 30, 2009 09:03 PM
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
killercrx91
Sep 23, 2008 08:16 PM
icet
Apr 19, 2005 06:15 AM
