Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Clutch Delay Valve -2010 EX
Old May 12, 2018 | 02:59 PM
timmytimm3's Avatar
Default Clutch Delay Valve -2010 LX
I searched and didnt find anything!! I have a 2010 Civic and the clutch is driving me nuts. I replaced the motor and tranny mounts and its still a pita to drive smoothly. Does the slave cylinder have a delay valve in it?? I bought a new slave and can’t find a DIY that looks like this one.
Thanks!!
Old May 15, 2018 | 06:13 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Clutch Delay Valve -2010 EX
Watch this video fam
Old May 16, 2018 | 05:26 AM
rick_rabies's Avatar
I'm not Rick!
you can buy a ktuned slave cyln. also adjust it where it connects to pedal. as in reduce the travel for it. maybe .5"
Old May 16, 2018 | 09:25 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Clutch Delay Valve -2010 LX
Thanks!!
If the 2010 LX (R18 motor) is anything like the 2007 Si (K20 motor) clutch setup, the delay chamber is on the master cylinder not the slave.
Some users swapped out the Si master cylinder for an EM1 master cylinder with swapping the push rod out.
It's better to just adjust the push rod to maximum travel to reduce the grinds challenge.
Once again this is only applicable if the R18 cars are like the K20 cars on the manual transmission pedal setup.
Old May 16, 2018 | 10:01 AM
I'm not Rick!
the SI slave cylinder does have a delay valve for sure........ does the R18? idk. but I seriously doubt the R18 and si have dif slave cylndrs. its a basic mech.
Old May 16, 2018 | 11:14 AM
foumer's Avatar
I will probably do this to my 2014 accord in conjunction with adjusting the push rod on the master cylinder like I did to my Si. My trans feels notchy at times.
Old May 16, 2018 | 12:19 PM
I'm not Rick!
clutch master can always be upgraded to bigger bore. (more fluid volumn pushed)
and a steel lining eliminating any rubber hose.
don't underestimate fresh clean fluid and completely bled does wonders
Old May 16, 2018 | 01:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I do not see provisions for the delay valve in the slave on the transmission. I only see the delay chamber on the master cylinder.
Old May 17, 2018 | 04:07 AM
I'm not Rick!
its inside the slave. you have to take off the rubber boot and rod. its at the end of the rod inside the boot
Old May 31, 2018 | 06:50 AM
timmytimm3's Avatar
Thanks for the replies, I've been busy and forgot to check back on this thread.
I'll pull the slave apart and take a look.
mrk904
Jan 17, 2011 03:57 AM
Hopesfallx2m
Aug 6, 2007 05:54 PM
ocks
Nov 15, 2005 06:52 PM
speedaholic92
24
Sep 8, 2003 04:14 PM
92CIVICCX
Oct 8, 2002 03:28 PM
