Honda Fit speaker w/ tweeter advice
Old May 9, 2018 | 11:44 AM
MTLian's Avatar
Default Honda Fit speaker w/ tweeter advice
Hello,
I'm looking to replace my 2007 Fit Sport lower door mounted speakers because my passenger side speaker is blown and I'd like a little upgrade in quality. I'm running the stock head unit and I don't need booming bass... the original speakers had sufficient bass for me. I like a nicely defined midrange in speakers since treble and bass can be adjusted.
I've found some pretty nice Polk audio speakers on crutchfield but these contain tweeters in the speaker. The Honda Fit Sport already comes with door mounted tweeters, mounted at the height of the side rear view mirrors. I'm thinking that the Polk Speakers with tweeters might be too bright. Is it recommendable to look for a speaker model that has no tweeter in them? Please advise. Thank you.
Old May 20, 2018 | 08:43 AM
thisguyaves's Avatar
Default Re: Honda Fit speaker w/ tweeter advice
Typically, you're either going to find coaxial (driver+tweeter) or component (Driver with separate tweeter) after market speakers. I've yet to see a speaker set that is just midrange driver. If you get a properly sized coaxial speaker with a silk tweeter (a soft tweeter design, not harsh), the distance from your ear and non-linear tweeter positioning will basically make the coaxial tweeter next-to-impossible to hear. I put kicker KS 6.5" coaxials in my 02 Si while keeping the original door pillar tweeter, and only got a nice deep midbass upgrade- the extra tweeter was un-noticable.
Old May 21, 2018 | 01:35 PM
MTLian's Avatar
Hey buddy. I didn't stop to think how directional high frequencies are. Since the lower spear is aimed at my calfs, the tweeters shouldn't contribute too much. Thanks for your great advice, I wasn't really looking to spend the big bucks and spend time modifying the electronics to install a component system. Your reply has helped me alot. Thanks!
One last question if you are watching the thread: do you install any additional soundproofing in your job? I think some factory speakers come with a foam ring around the speaker casing to avoid rattling against the door. Is some kind of foam backing recommended?
Old May 21, 2018 | 02:29 PM
I watch everything car audio related on HT, lol.
I keep the original foam ring on the door panel if one exists. For the sake of anti-vibration, I make a gasket of hush-tape, dynamat, or similar aftermarket sound deadener. With the hole I cut in a square of that, I place the circle inside the speaker hole on the inside of the door skin directly behind the speaker. Hopefully this cross section helps.
If you're asking about a ring between the speaker face and grille that's built into the door panel, you really only have to worry about that in SQ applications. If you're not trying to drop $500 on a speaker set, don't bother honestly. Throw it in there if you want, no harm done, but I certainly never have on budget builds.
Old May 21, 2018 | 09:26 PM
Meyata's Avatar
Thanks for the drawing. I need to check on that anti vibration thing because my door buzzes alot.
Old May 22, 2018 | 03:17 PM
I recomend Stinger Roadkill personally, but it's all the same. Like a heavy, adhesive tar on a aluminum foil feeling backing.
hieungu1155
Audio / Security / Video
15
Sep 21, 2009 08:10 PM
Whats_the_w0rd
Sep 10, 2006 12:24 PM
Kryptonite
Jan 13, 2004 04:31 PM
Unjockable
12
Dec 15, 2003 10:22 AM
Loveless
Feb 20, 2003 09:38 AM
