Sensor question
What sensor is this & how do I remove it? Pulled the screws and it wouldn't budge, should I just pry it out?
all the sudden my car is idleling rough, cuts out when I give it throttle and when in neutral it hits rev limiter at like 2? Think this sensor got damage when a buddy was re routing my harness
thats a fuel injector bro
your intake manifold only has two
and you broke one haha
yes it prys off to change out just be gentle
the bottom one is to keep the car on at idle
and the one you broke is the one that gives your motor gas when you press down on the gas pedal and rev the motor
Ah that'd make sense! Lmao
i figured it was something to do with air/fuel mixture. Good to know!
I'm pretty sure he dropped or knocked the throttle body over when we took it off to change the spacer/gasket and clean it up. Doesn't make sense that it got broke just disconnecting it lol
thanks man! I have a spare on an extra intake/TB from my old blown engine, didn't wanna break the good one trying to swap em
thanks man!!
thanks man!!
