Engine Rev by itself?
Old Mar 10, 2004 | 09:00 PM
vandeec5's Avatar
Default Engine Rev by itself?
I was in my cousin car and i started it and like 10 sec later the engine started to rev by itself. The idle would jump from 1000 rpm to 2500 rpm and then drop and do the same thing. up and down, up and down ect. then i steped on the gas and it went away. 10 sec later it did the same thing. What can be the problem?
Old Mar 10, 2004 | 09:17 PM
3.504's Avatar
Default Re: Engine Rev by itself? (speedrlcer)
bad IAC (idle air control).... its a neat little solenoid valve on the back side the intake manifold... try cleaning it w/ carb. cleaner... if that dont work... go to a junk yard and pick up a new one.... it also might be tps sensor (throttle position sensor) thats mounted on the throttle body... thats just something you can only replace... agian, junk yard....
Old Mar 11, 2004 | 06:07 AM
vandeec5's Avatar
Default Re: Engine Rev by itself? (3.504)
Hey thanks alot man i will try and get a new one thanks alot
Old Mar 11, 2004 | 06:26 AM
foxfai's Avatar
My car does the same thing when i start the car on a wet weather or moist. But after it warms up, it's gone. Do you guys think it's the same thing needed to clean the sensor??? Carb cleaner will work??? (finding out where to get seafoam )
Old Mar 11, 2004 | 08:38 AM
Jinya1004's Avatar
Default Re: Engine Rev by itself? (foxfai)
Might be a vacuum leak
Old Mar 11, 2004 | 09:04 AM
3.504's Avatar
Default Re: Engine Rev by itself? (Jinya1004)
yep, vacumm leak can be it too.... seafoam will work for that... usually hear a hiss sound... but sometimes you dont.... but try those sensors and if you have an engine check light on... easiest thing would be read code then fix what the code says is wrong
Old Mar 11, 2004 | 09:05 AM
MikeTV
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jinya1004 &raquo;</TD></TR><TR><TD CLASS="quote">Might be a vacuum leak</TD></TR></TABLE>
Dude, thats a pretty funny avatar
legacy1644
Oct 18, 2008 12:05 AM
ONE-CAM-EF
10
Jan 20, 2008 12:31 PM
talde
Jul 21, 2007 03:12 PM
HondaEF
Nov 28, 2006 10:46 AM
standbackimapro
Apr 29, 2006 06:23 PM
