Troubleshooting: Is the following a Blow off valve limitation or other issue?
Old May 8, 2018 | 02:10 AM
Lalasus17's Avatar
Default Troubleshooting: Is the following a Blow off valve limitation or other issue?
Hey. My blow off cant handle over 2000rpm pressure in intake. What's can i do to prevent it? Civic VI D15Z6 Eaton M65
Old May 8, 2018 | 03:25 PM
TheShodan's Avatar
Moderator
Default re: Troubleshooting: Is the following a Blow off valve limitation or other issue?
What you're describing is not compressor surge
Old May 11, 2018 | 11:01 AM
Autoworks's Avatar
Default Re: Troubleshooting: Is the following a Blow off valve limitation or other issue?
Are you saying the valve will not stay closed above 2k rpm?
Old May 12, 2018 | 06:00 AM
850Fabrication's Avatar
Being a supercharged application, those little chargers can make boost really quick. You need to remove the bypass valve and test it to ensure that it is working properly.
This can be done easily with a vacuum/pressure tester. If while bench testing, it cannot hold pressure, you need to replace the valve or repair whats damaged.
supercharged d
Aug 6, 2009 03:59 PM
petrv
Aug 26, 2005 02:26 PM
civic_dork
Aug 21, 2005 10:50 AM
Hyaboosta
Mar 16, 2005 06:29 AM
graphic
Sep 24, 2004 08:17 AM
