H23a Bluetop
Old May 6, 2018 | 07:40 AM
ymerejOG's Avatar
Default H23a Bluetop
i am changing oil pan on h23a bluetop. What oil pan can I use ? F23 the same?
Old May 6, 2018 | 11:38 AM
SubwayH23's Avatar
Default Re: H23a Bluetop
You could look up the part numbers for each and then see if they match
Old May 6, 2018 | 08:40 PM
TimiK's Avatar
10 Year Member
depends what transmission you have
H22 92-96 oil pan dont have attachment point to newer transmissions so they dont click together that good
pick up could be wise to match the oilpan also
Old May 7, 2018 | 11:31 AM
ESP.net's Avatar
F23A Oil Pan and Pickup and H23V BT same part #s
H22 pan will not work on it unless swap oil pickup for H22... have to have matching pickup and pan
Old May 7, 2018 | 12:22 PM
ISUBIEXI's Avatar
I used the H22A4 pan on mine when I swapped it from the Accord to the Prelude. I'm pretty sure mine were identical. Its possible that I didn't have the stock pan/pickup on my engine so that could be it as well.
Old May 7, 2018 | 03:25 PM
ymerejOG's Avatar
If I get h22a4 pan I should change pickup also?
Old May 7, 2018 | 07:31 PM
ISUBIEXI's Avatar
I would definitely defer back to ESP but for mine the pickups were identical between the h23AV and H22A4. Both had steel pans. I used the A4 gasket oil pan gasket as well.
I assume as long as the pickup matches the pan you should "should" be ok.
Old May 8, 2018 | 12:20 PM
ESP.net's Avatar
H23V Blue Top Motor:
H23V Oil Pan and Pickup = F23A part #
- Pickup is taller
H23V Oil Pan and H22 Pickup= Pickup may be too high may not have issue, May have oil pressure issue, vtec not work... maybe not
H22 Oil Pan and H23V Pickup= 1/4" gap all around wont bolt up unless force and bend pickup when tightening. DO NOT DO... Pickup will be on bottom of Pan starving for oil, No Oil Pressure, Or Lack of Oil Pressure and NO VTEC.
H22 Oil Pan and H22 Pickup= Works
Simply Match Pickup to Pan you are using whether H22 or H23V/F23A
Old May 8, 2018 | 01:02 PM
ymerejOG's Avatar
- Pickup is taller
I will be getting 1998 h22a4 oil pan with its matching pickup.sounds like the best route! could I use the gasket also even tho bluetops don’t have from factory? ! And do you know the torque should be on pickup tube? Thank you
Old May 9, 2018 | 06:01 AM
ISUBIEXI's Avatar
I don't know what's recommended as far as Gasket. I know some pans have the little nubs that keep the gasket somewhat in position and keep you from completely crushing the gasket. In this case it took a little time to slowly make sure every bolt lined up with the holes but it worked just fine and I have no leaks.
Old May 9, 2018 | 08:30 PM
TimiK's Avatar
10 Year Member
I have used Loctite silicone gasket maker
thirsk66
Oct 9, 2015 09:31 AM
Prudz_lude
Oct 20, 2009 10:18 AM
speedworks
Nov 15, 2005 07:19 PM
Aaron.Hillman
Mar 3, 2004 09:02 AM
Mighty Mintos
May 24, 2003 11:49 AM
