Honda CR-V & Element 2WD & 4WD Element & CR-V
Better horn for 2018 CR-V
Old May 4, 2018 | 12:36 PM
ChiefKAW's Avatar
Default Better horn for 2018 CR-V
Is it possible to put an Accord horn into a 2018 CR-V? The Accord has a real horn. Not sure why Honda puts that wimpy horn into the CR-V.
Old May 7, 2018 | 05:18 AM
ClabbeB's Avatar
Default Re: Better horn for 2018 CR-V
Everything is possible...
I installed a Stebel Nautilus horn on my V instead...
Old May 13, 2018 | 12:16 PM
ChiefKAW's Avatar
Well that horn is much better than the meep-meep CR-V horn. Does it go right in to replacing the CR-V horn or is there wiring modification needed?
Are there any horns that will simply replace the meep-meep one with real horn sound and no wiring or voltage concerns?
I like the sound of this Nautilus horn, so it's a possibility.
Old May 13, 2018 | 11:33 PM
ClabbeB's Avatar
You will have to install a relay and pull a few cables since it is so powerful.
Pulls a bit more power than the regular meep-meep horn.
I have it connected additionally to the meep-meep for more sound
Old May 19, 2018 | 11:21 AM
ChiefKAW's Avatar
So how about a "plug n play" horn, one that allows me to disconnect the CR-V meep meep horn and connect a real sounding horn such as the Accord sound? One that I don't have to pull cables and/or power. Maybe??
Old May 21, 2018 | 03:06 AM
Type X's Avatar
I installed stebels on our crv when i had the front end off doing the touring headlight retrofit.
install was very simple and hey are night and day upgrade over stock.
you can do the install by just sliding off the shroud its that easy
Old Jun 4, 2018 | 05:42 PM
ChiefKAW's Avatar
Thanks for the replies Type X and ClabbeB. Turns out with a little "searching" this was a very simple job. My biggest concern was how to connect new horns to the CR-V wiring. The horn adapter harness I found online at College Hills Honda was key to this being a simple process. I ordered 2, they came very quickly, no trouble at all. Then I bought two universal connection horns (the kind with two prongs since it's so hard to find 2017-2018 Honda compatible horns). These adapters end up giving you many options in what horns you want to buy since you just need to have two tabs to connect to.
Removing the shroud under the hood is very easy, 8 simple holders to remove. Then pull the fuse, unplug the old horns, remove them, plug in the adapter harness, connect the other end to the horn, easy fit in place, fuse back in and a quick test before replacing the shroud. It took about 30 minutes mostly because I was taking my time to make sure I didn't misplace any bolts or the holders for the shroud.
Now I have a horn that sounds like a Honda should sound. Easy and relatively inexpensive.
brettnelson232
Honda Civic (2016 - Current)
Apr 10, 2019 10:42 AM
questionquestio
Honda Civic (2006 - 2015)
Oct 11, 2010 08:14 PM
NWFA5
18
Aug 4, 2009 07:05 PM
gosu08
May 7, 2009 05:17 AM
indntechsupport
Oct 24, 2006 10:08 AM
