Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic eu8 2001 D16V1 stalling when it's warm
Old May 3, 2018 | 12:51 AM
Danijel's Avatar
Default Honda Civic eu8 2001 D16V1 stalling when it's warm
Hello!
Here is the interesting problem that I'm facing with, and don't have a solution for it. Hopefully you guys can help me.
Here is what is happening:
During the summer time (or when it is above 22 degree C) after about 20 minutes of driving, my Honda stalls. No matter if I'm on the stop light or driving, it just shuts down. If I try to start it again, it just keeps cranking, or if it starts, immediately turns off again. If I let it cool down, approximately 20 mins or half an hour, everything is fine, but again, next day, same story.
So far, I clean the throttle body, EGR valve, IAVC valve, change the spark plugs, check for the vacuum leaks, change the crankshaft sensor.
I was thinking that maybe it's one of the ignition coil, fuel pump, or the TDC sensor, but before I do that stuff, I wanted to ask for your opinion.
I put the OBD scanner (cheap ebay scanner) and when the problem occur it showed me the P1361 code - TDC sensor intermittent interruption, but I don't know if I can trust to that scanner.
During the winter period, car is acting perfect.
What is your opinion?
Thanks in advance!
Danijel
Old May 3, 2018 | 07:14 AM
NDNV's Avatar
Default Re: Honda Civic eu8 2001 D16V1 stalling when it's warm
Reset the PCM and see if the code or problem comes back.
Try another reliable scanner and if you get P1361 again, check the continuity on the TDC sensor to see if it is faulty. Otherwise, check for an open/short in the circuit and grounds.
Did this issue start to occur after a timing belt service? May have loosened the connector or someone mentioned to remove harness to sensor and spray with electrical contact cleaner and reattach helped solve this code.
Slowsolow_
Paint and Body
May 15, 2018 05:50 AM
ZeroConsequence
Aug 21, 2017 08:36 PM
Jakester9500
Mar 20, 2017 06:54 AM
[S]niper[W]olf
May 19, 2015 06:06 AM
CA6VTEC
Oct 22, 2009 04:16 PM
