Transmission & Drivetrain Gearboxes, Differentials, Clutches
Big bearing L3 gearbox in CRX. What axles?
Old May 2, 2018 | 01:14 PM
4Trouble's Avatar
Default Big bearing L3 gearbox in CRX. What axles?
Hi everyone!
I've put a quife lsd in a big bearing l3 gearbox (CRX ED9, D16A9), but, someone else was stripping this gearbox before me, so it has different ratios, and it had... small side gears in a diff... yeah, they are for 26mm axles (again, big bearing diff 40mm, and smal side gears 26mm).
Now, I've got, big axle diff, and small 26mm axles.
What axles can i fit?
A DA Integra inner cv + crx shaft, and outer?
Old May 3, 2018 | 05:17 AM
Aquafina's Avatar
Default Re: Big bearing L3 gearbox in CRX. What axles?
If it uses standard D series axles in the diff, then you just use normal D series axles. You can't use the B series axles if it has the standard sized axle side gears.
Old May 4, 2018 | 04:37 AM
4Trouble's Avatar
It had small axles. Now i need to convert it to bigger ones because of lsd side gears size(27 teeth).
Old May 7, 2018 | 02:15 PM
94EG8's Avatar
Seagull Management
I'm pretty sure all the D-series inner joints are the same. 35mm and 40mm diff bearings both used the same inners. The outer joints are smaller on the HF models though.
Old May 28, 2018 | 11:31 AM
Aquafina's Avatar
Then you need to use B series inners.
Keebler
Jan 15, 2021 03:12 AM
JDMotive
Aug 4, 2004 08:54 AM
McDade
Sep 1, 2003 07:49 AM
