2000 Honda civic LX, crank no start.
Old Apr 30, 2018 | 12:24 PM
GiantDad's Avatar
Default 2000 Honda civic LX, crank no start.
2000 Honda civic LX D16YZ engine, 4 speed auto, crank no start, no injection pulse, no spark. DTC's are unknown because I do not own a scanner.
No control on coil (-), test light stays lit, coil is not shorted or open because I was able to bypass the ICM and make the coil spark.Here's what I've gathered so far, everything AFTER the ignition coil is good, however the control side is suspect.How do I check 5 volt reference of PCM wires and inputs such as the CKP?
Old Apr 30, 2018 | 01:23 PM
mk378's Avatar
Default Re: 2000 Honda civic LX, crank no start.
Turn the key on but don't crank. The check engine light should come on for 2 seconds then go out. The fuel pump should run during those 2 seconds then stop.
If it doesn't do that, the ECU has not booted up at all, so there's no way the car can start. It will not drive the ICM or the injectors.
Old Apr 30, 2018 | 03:41 PM
GiantDad's Avatar
The check engine light does not come on, however I heard many people just remove the bulb so I don't want to think it's not on and it really is. Does that make sense.
Fuel pump does prime, I can hear it and smell the raw gasoline out the tailpipe from the prime.
Old Apr 30, 2018 | 04:40 PM
mk378's Avatar
You should fix the CEL bulb in that case, it is good to know about problems that may develop, and it's an important thing to check in this case. Also if you're going to work on an OBDII car you should own a scanner.
Does the fuel pump start and then stop when you turn key on and don't crank?
Old Apr 30, 2018 | 05:14 PM
GiantDad's Avatar
Yes it does.
Also I never touched the CEL, if it's gone the previous owner did it.
Old Apr 30, 2018 | 06:16 PM
fonkernuckle's Avatar
Using a t-pin at the connector at the crank position sensor or at the sensor to harness connector test each wire: one should be a pwr feed some are 12v some 10v but I believe honda is 5v and one is a ground and the third is the signal wire consult the schematic for your car. test while cranking:The signal should be 0- 5v square wave on a scope but if all you have is a multimeter then instead of cranking-bump the key and you should be able to see a varying voltage reading after each bump on the multimeter 0-5v that would say the crank sensor is good. Use battery ground.
Old Apr 30, 2018 | 07:35 PM
GiantDad's Avatar
Sound like plan! I'll check it out soon.
Old Apr 30, 2018 | 07:57 PM
GiantDad's Avatar
Old May 5, 2018 | 11:53 AM
GiantDad's Avatar
Where is the crank position sensor located?
Also where is the harness side?
I'm completely lost.
Old May 6, 2018 | 01:34 PM
GiantDad's Avatar
Update.
Key OFF (Literally in my hands at this point) PCM driver appears to be shorted, with test light connected to power, the control wire STAYS lit/on
Disconnected PCM
Test light goes out
What do you guys think?
Old May 8, 2018 | 08:47 AM
GiantDad's Avatar
I'm still at loss here guys
Old May 24, 2018 | 07:42 AM
GiantDad's Avatar
Lots of progress so far.
Tested for 5v references and they are not present.
I got .030 - .170 volts.
TPS sensor is unresponsive, the readings stayed static even when at WOT.
G101 computer ground is good.
No short to ground on sensor wires.
No open on sensor wires.
Sensors wires have a good ground.
I have to say it must be the ECM. Circuit integrity is good all around
Old May 24, 2018 | 01:01 PM
MyAcc0rd's Avatar
I'd say go to autozone/oreilly or whatever parts store is around you, and get a loaner scan tool to pull any codes... doesn't sound like you've tried that yet.
Old May 24, 2018 | 01:10 PM
GiantDad's Avatar
I guess I could try that, but I doubt the scanner will even be able to communicate.
Old May 25, 2018 | 01:48 PM
GiantDad's Avatar
Well guys, I'm about to buy the car car for car for car for carfor $350, I'm about to become a genuine honda owner soon.
The perks of being a grease monkey!
Old May 28, 2018 | 10:18 AM
jven3569's Avatar
Check ignition coil, check spark plugs, common cause can be the Main Relay. Main Relay symptom is fuel pump not engaging (though Fuel Pump is functional). Main Relay behind Glovebox, check those wires with light test, if Yellow/Black don't light up than change PGM-FI (Main Relay)
civicali
12
May 24, 2019 05:01 PM
Joshua Parker
Aug 7, 2018 02:33 PM
GiantDad
Apr 27, 2018 10:44 AM
Alfarano
Sep 30, 2016 03:39 PM
fsjeep
Jun 28, 2009 03:10 PM
