Shaft seal for distributor H23A1?
Old Apr 27, 2018 | 08:31 AM
Rotting Prelude's Avatar
Default Shaft seal for distributor H23A1?
1994 Honda prelude Si. I have an oil leak coming from the bottom of my distributor, it leaks all over the coolant temp sensor and sender. I believe this is caused by an O-Ring called the outer shaft seal or something like that. Anyone know if I am correct and if so where I could find this part? Having trouble looking it up. Oil does not leak into the distributor itself, just where the distributor meets the cam. It's a slow leak, not bad at all, but it's annoying me a bit and I want to fix it.
Old Apr 27, 2018 | 12:16 PM
holmesnmanny's Avatar
Default Re: Shaft seal for distributor H23A1?
there is an oring that goes around the shaft where the dizzy shaft meets the cam
you will need to use a marker to make a mark on the dizzy where it meets the head so that when you take off the dizzy you can put it back in the same exact spot so you don't change the ignition timing
Vtec_India
Feb 15, 2016 10:15 PM
Cameron k.
60
Sep 25, 2012 07:19 PM
realred96
Classic Hondas
Sep 25, 2011 06:26 PM
jchrm80
May 17, 2009 09:27 AM
blackmfoggie
Aug 23, 2007 12:09 PM
