Is this a good way to seal the oil pump
Old Apr 22, 2018 | 09:27 AM
89ED's Avatar
Default Is this a good way to seal the oil pump
Is it?
Old Apr 22, 2018 | 11:31 AM
Kramer5702's Avatar
Default Re: Is this a good way to seal the oil pump
They dont come with a gasket? If no gasket is supplied/offered then 9/10 no gasket is needed. I see the O-Ring and if thats all thats available then you dont need the copper sealant.
Old Apr 22, 2018 | 11:56 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
No, you need hondabond/rtv.
Old Apr 22, 2018 | 12:57 PM
89ED's Avatar
I suggest using either of these. I didn’t like that the copper spray said it was good for heat transfer.
Old Apr 22, 2018 | 02:19 PM
Kramer5702's Avatar
Only time I used to use copper spray was to hold a gasket in place during installation.
Old Jul 8, 2018 | 09:48 PM
YoungMoney_Twit's Avatar
Can you use the spray and leave the gasket over night and still be good to use?
Old Jul 10, 2018 | 05:41 PM
89ED's Avatar
Don’t use the spray bc it’s designed to transfer heat.
Old Jul 10, 2018 | 09:01 PM
acmoc's Avatar
yep, this stuff. It's what you use on the upper rad hose blok adapter
jlfrnce
Sep 15, 2009 09:07 PM
ketchup
Apr 19, 2008 10:32 PM
acurar0ss
May 18, 2005 07:34 AM
DriveSlowHomie
Apr 1, 2005 04:37 AM
Jonathan_ED3
Apr 11, 2003 09:02 PM
