spring compressors
Old Nov 12, 2002 | 02:06 PM
crxmadman's Avatar
Default spring compressors
i was doing a search on whether spring comperssors are necessary or not to remove stock springs off the strut assembly and i came up with some options:
1) the "Jeff S" method of loosening the shock tower bolt while the car is still on the ground then letting the spring uncompress itself when jacking up
2) using an impact wrench and allowing the assembly to pop out
has anyone tried jeff's method? sounds a lot safer
Old Nov 12, 2002 | 02:32 PM
TREVER's Avatar
Default Re: spring compressors (4doormadman)
The first method can make it hard to remove from the car.
I use the gun and shoot it into the tire. I lay a towel over the strut so nothing would go shooting
Old Nov 12, 2002 | 03:11 PM
dut's Avatar
dut
Default Re: spring compressors (TREVER)
-just pop it off, no need for a compressor...
-put the strut assembly in between the tire and wall with some space provided for the spring to fly off...
Old Nov 12, 2002 | 04:33 PM
3rdGteg's Avatar
Default Re: spring compressors (dut619)
or you can make a run to autozone or was it pepboys, that rent out them coil spring compressors for free; just leave a deposit and get the whole deposit back when u return the tool=free.
hondaboy4life
Jun 24, 2006 04:38 PM
hondaracing1
11
Mar 24, 2005 06:24 PM
grandmasterflex
16
Dec 22, 2003 08:59 AM
Ignitecivic
Mar 17, 2002 04:37 PM
