01 Civic EX AC Compressor going
So I've had a bearing sound coming from my AC compressor. Probably been like this for the last year, AC hasn't worked before that even. I want to finally take care of this. What are the best options? OE compressor is like $250.
Aftermarket Kit? Easy to install?
Disconnect it? If so what's the easiest way to do this? I don't ever really use my AC...
You can temporarily install a DX belt to route it away from the compressor or you can buy a new bearing and pull the pulley and just press in the new bearing.
https://www.ebay.com/itm/AC-Compress...5Tv~a-&vxp=mtr
Any additional things to do if I used a different belt or is it same exact thing as normal belt?
many how-to's on youtube for replacing ac pulley bearing
What I might do is order both the bearing and belt. If I end up messing up when trying to replace the bearing, at least I'll have a belt to throw on.
I'll report back in a week or so if I ever get around to doing this
the pulley bearing is the compressor bearng, same thing
a new ac clutch kit includes the pulley, clutch, and coil and might be your best bet if you cant do the bearing yourself, but you will need to measure the clutch gap when using the supplied shims
plotomatic
Sep 24, 2016 11:10 AM
dj_justice
Jul 19, 2013 12:18 PM
c1v1c98
May 3, 2012 03:01 PM
melsun_ap1
Sep 14, 2007 06:59 PM
