Suspension & Brakes Theory, alignment, spring rates....
Identifying rear wheel hub/bearing sizes
Old Apr 13, 2018 | 10:12 AM
baummy's Avatar
Default Identifying rear wheel hub/bearing sizes
I have an EK with a rear disc conversion with ABS however I am not sure what model it is from. I went to replace the rear hub/bearing with one for a 96 EK without ABS (which I think just doesn't include the ring) but the inner diameter of the bearing is too small to fit over the spindle. The bearing ID measures 28mm and the one I removed is 30mm. What model is this 30mm spindle from?
Thanks,
Matt
FSRslug
Apr 21, 2009 03:04 PM
Blamm!!
Aug 14, 2008 06:50 PM
Streetneon2185
Jun 5, 2007 09:39 PM
bow tie
24
May 2, 2007 06:09 PM
triggerstep
Dec 19, 2006 08:17 PM
