Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Manual key lock will not work after replacing actuator
Old Apr 13, 2018 | 09:33 AM
NikkiS531's Avatar
Default Manual key lock will not work after replacing actuator
I recently replaced the driver's side door actuator on my 2010 Honda Accord EXL. When my friend went to install it, there was a part that snapped into the right side, had a tip that looked like a flat head and had a white cap that snapped on. I believe he may have broken that because it would not snap back on. One day I tried to use my key to open the day and it wouldn't unlock. Could it be from that part? What was it if so? Or maybe did the lock rod come off? HELP!!
Old Apr 13, 2018 | 11:59 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Manual key lock will not work after replacing actuator
Sounds like you're referring to inner handle cable (white cap). If that part is broken, you can get the inner handle cable from the dealer. List price is $6.97.
Take the door panel apart to see what is the issue.
Old Apr 13, 2018 | 01:21 PM
NikkiS531's Avatar
Thank for responding. I actually found the piece that broke. It’s the number 16 in the diagram I attached.
Sportsgirl05
Apr 12, 2017 05:28 AM
nhanimator
Apr 14, 2011 07:12 PM
SmogKing
Nov 4, 2010 11:00 PM
acole3
Sep 26, 2008 07:46 AM
Mike1982
Jan 30, 2007 02:17 PM
