Question about DC header
I'm looking at DC AHC6511 and it says it's only for '00-'01 GSR. It should fit on all other Integras except for '94-'99 GSRs right? Just making sure that it'll fit on my '96 RS that has stock exhaust right now.
Do you have any other recommendations? I'm putting this on a bone stock B18B right now that I was just looking to get a little more mid-range power out of with a few bolt-ons. The reason I was looking at this one is because while it's a 4-2-1 header, it's still one piece so I don't have to mess with gaskets in the middle like other 4-2-1 headers.
DC isn't junk, it is decent quality, but don't think of them as a performance header, they are more of a good looking oe replacement for some added bling. I would be surprised if the dyno showed any noteworthy gains. I will tell you that the 1 piece will be a pain in the *** to install compared to the two piece. I am not sure where you got the idea that 2 piece DC headers required messing with.
If you are just wanting to clean up your engine bay, DC would be a good route.
If you are wanting actual performance, a more dedicated full length header from PLM or 1320 etc and a full custom exhaust would probably be a better idea.
Any of these "bolt on" headers aren't going to do a whole lot.
A header like this one is more likely to improve performance:
https://www.privatelabelmfg.com/prod...b18-header.htm
Because it has a long tube design that allows the primaries and secondaries to reach a more optimal length before merging, due to this, they are too long to bolt on to the factory exhaust and would require a custom length exhaust/test pipe etc....
I've had 2 DC sport headers crack at the collector, but in general they are decent products. I have not have any trouble installing a 1 piece header. Slides right in, even with AC.
Agreed, it's basically just a lighter and cheaper OEM replacement header. While CAI will make a noticeable difference in sound and power, I could never tell the difference with just a header.
Yea I plan on also putting in the Comptech CAI as well when I do the header. For the DC header I mentioned, the dimensions are the same between 00-01 GSR and my 96 RS so I would just need to cut and rotate that flange at the end but if it's really not going to gain any performance than I think I'll go with a better option. That Private Label header that CandyRed linked seems like a really nice one and it's not too expensive either. I'm not too worried about using a CAT as I'll always have the stock exhaust handy whenever I need to pass emissions. But theoretically, if I got a 2.5" CAT and cut the B-pipe shorter to fit, and got an extension for the secondary O2 sensor wire then couldn't I still use that Private Label one with a Cat?
And when I received the one I previously ordered, the oxygen sensor bung had a hole in it and they wouldn't warrant it. I had to have it welded. I wound up just going oem.
https://www.google.com/search?q=hond...hrome&ie=UTF-8
yes the header for usdm 00-01 GSR should fit usdm 96 RS.
All USDM integra 94-01 LS/RS/GS/ITR and USDM 00-01 GSR have the same exhaust fitment. Only 94-99 USDM GSR have different fitment.
94-01 gsr and 94-01 ls gs exhaust ??? - Team Integra Forums - Team Integra
Greddy Sp2 On 00 GSR - Team Integra Forums - Team Integra
I just measured it and ID was just a bit over 2" but that's because of the bottle neck on the ITR b pipes. I'm sure if I was able to measure the ID past that initial bit it would be 2.25"
My 2000 Integra LS hatch w/auto:
In 2002 I installed a DC AHC 6504 (4-2-1 ceramic) header on my Integra.
The box that the header came in said that it was for a 97 - 98 Type R.
My Integra, at that time, had its OEM B18B1 engine. I noticed an improvement. Perfect fit and no issues.
In 2012, when that engine started burning oil, I replaced it with a JDM B18B and used the same header. No issues and perfect fit.
A good rule of thumb: if you spend $100 expect to gain 1 HP.
streetmodified
May 22, 2006 07:53 PM
jeffk182
38
Dec 28, 2004 11:20 PM
