main relay no ground k swapped ek civic
Old Apr 2, 2018 | 06:13 PM
fuzzysig's Avatar
Default main relay no ground k swapped ek civic
im troubleshooting a 96 rhd ek civic with a k swap
rywire harness
aem ecu
the car started and drove few months ago
then was parked in garage with battery tender on it
now it cranks but wont start
main relay is tested and good
no ground to main relay
12 volt and ignition is there
also 12 volt to ecu
and the "thermostat" ground is good also at the terminal on valve cover
it clicks when i ground the relay at connector but fuel pump doesnt prime
fuel pump works when i put power on it at the relay
besides break in the ground wire what else can it be?
Old Apr 4, 2018 | 11:10 AM
fuzzysig's Avatar
Default Re: main relay no ground k swapped ek civic
any common issues with rywire harness?
Old Apr 9, 2018 | 09:38 PM
fuzzysig's Avatar
went to look at it some more today
battery tender didnt even charge the battery the whole week
strangely today the main relay has ground but still doesnt click or prime fuel pump
and the ignition chime is gone
this is definitely some crazy electrical issue i just dont know where to look
can it be circuit behind underdash fuse box ?
or dash harness?
it seems like the rywire ecu ground is there
main relay shows ground mmagically
battery doesnt charge and even when jumped still no start
i looked at all the wires and plugs and see nothing that is obvious to me.
is there anything special about jdm EK dash harness at all?
im suspecting either burned ground wire in the dash harness or a short in the fuse box
but its been a while since i dig through the electrical systems on ek so i forgot some already
Jamesb223
Jan 21, 2018 08:01 PM
LowNSlow96ls
Aug 10, 2014 07:32 AM
Taylorej1-93
14
Jan 29, 2013 08:02 PM
slowpokecivic
Jul 26, 2012 07:37 PM
ohsnapzafingcu
Oct 15, 2011 11:33 PM
