Alarm 1997 honda
If it was related to an aftermarket alarm starter kill, the installer will normally cut anywhere along the ignition switch wire harness that plugs into the under-dash fuse box (Connector C906) and runs under the dash up to the steering column ignition switch; the cut will be either at the wire near the fuse box connector or along the harness under the dash. The starter wire is Blk/Wht (which is a wire with black color insulation and a white stripe).
Can you take photos and post the black box and wiring?
eternaljihad
Audio / Security / Video
Dec 15, 2004 02:05 PM
