Troubleshooting: Manual Boost control overboost issue (Ball&Spring Type) *SOLVED*
Old Mar 26, 2018 | 12:36 PM
hondamyheart's Avatar
Default Troubleshooting: Manual Boost control overboost issue (Ball&Spring Type) *SOLVED*
I am having overboost issue with my 98 prelude h22 turbo. I set the boost controller to 8psi but it I floor it, it will just go higher psi and hit the boost cut. I tried to run straight line from turbo to wastegate but same , the wastegate seems not opening. I pulled the wastegate out and test it with air compressor it is working. I double checked my vacuum lines all good. My vacuum lines setup: bov to IM, boost gauge to IM. I have turbosmart mbc so the turbo compressor npt fitting goes to the T and the other side of the T goes to the wastegate ( there is an arrow on the T which manual says wastegate should be connected to it).
Old Mar 26, 2018 | 01:04 PM
TheShodan's Avatar
Moderator
Default re: Troubleshooting: Manual Boost control overboost issue (Ball&Spring Type)
change your vacuum source from the compressor nipple tip the intake manifold. Compressor cover is too strong.
Old Mar 27, 2018 | 07:37 AM
so I will just cap the pressure source of the turbo and run the vacuum line from the wastegate to intake manifold?
Old Mar 27, 2018 | 09:39 AM
TheShodan's Avatar
Moderator
Yep. Or a vacuum manifold that is using the brake booster as its main vacuum source.
Old Mar 27, 2018 | 09:47 AM
TheShodan's Avatar
Moderator
Default re: Troubleshooting: Manual Boost control overboost issue (Ball&Spring Type) *SOLVED*
What you're using is a Ball-Spring type MBC, and not a bleed-style MBC. There are some subtle differences.
These controllers still use a bleed, but the most common technique is to place a steel ball behind the restrictor hole, held shut by a spring. The main problem with this technique is that since the restrictor hole is so critical to boost, placing a free-floating ball behind it adversely affects its performance. Because the ball is free-floating, it can act like a pea in a referee’s whistle, fluttering around in the restrictor hole. This then causes boost fluctuations, and (if the spring is set incorrectly or you have a boost reference issue) boost spikes.
It's still a great controller. I'd only use this or a Hallman-ES controller if I were staying manual. But I have noticed over the years that compressor cover references as boost sources can give some seriously undesired results.
I hope that helps you understand a bit better as to the "why" of things.
Old Mar 27, 2018 | 10:45 PM
thanks for the clarification. But even if I shut the controller completely it will still read boost at 4K rpm the boost reaches 10psi . I tried my buddies controller but same thing happening. I will just run the wastegate source from the IM and let you know the results
Old Mar 28, 2018 | 07:25 AM
TheShodan's Avatar
Moderator
Again, more likely due to boost reference. Also verify that your spring used is for whatever you're looking for less than 10psi. It can also be due to retarded (conservative) timing . That can & does contribute to the issue.
There are several aspects involved with this issue. Not just the controller, or just the reference point. So you have to attack each area individually.
Old Mar 28, 2018 | 10:40 PM
thanks buddy I was bit stupid didn’t get it from first time lol. In my case I have 5psi spring.The wastegate will read the pressure once it reaches 5 psi the valve will open. So if the wastegate is not getting pressure it won’t work. I will work on it tomorrow starting from the vacuum source. Thanks again.
Old Mar 29, 2018 | 02:01 PM
TheShodan's Avatar
Moderator
thanks buddy I was bit stupid didn’t get it from first time lol. In my case I have 5psi spring.The wastegate will read the positive pressure once it reaches 5 psi the valve should open. So if the wastegate is not getting proper vacuum it won’t work. I will work on it tomorrow starting from the vacuum source. Thanks again.
Just helped fix that for you so, you understand how this works a bit better.
Old Mar 30, 2018 | 04:47 AM
My problem solved. Thanks
Old Mar 30, 2018 | 06:18 AM
TheShodan's Avatar
Moderator
So what'd you finally do? I'd like to give this thread some closure.
Old Mar 31, 2018 | 09:48 PM
I plugged the turbo compressor nibble. Then I run the wastegate vacuum source to the intake manifold.
Old Apr 1, 2018 | 10:06 AM
TheShodan's Avatar
Moderator
Excellent.
98integralsB18
Jul 25, 2009 07:29 AM
Gunner142
Feb 9, 2009 04:39 PM
DIRep972
Sep 11, 2004 01:26 PM
_Endless_
Sep 23, 2002 10:00 PM
