Transmission & Drivetrain Gearboxes, Differentials, Clutches
2003 Civic -New clutch won't engage
Old Mar 25, 2018 | 05:10 AM
OldJoe's Avatar
Default 2003 Civic -New clutch won't engage
2003 Civic - New clutch, pressure plate, throwout bearing, master cylinder, and slave cylinder. Bled with vacuum bleeder. No leaks, no air bubbles left, clean new fluid. Pedal goes to floor, slave cylinder does not push fork. I even put old clutch back in and had same problem... I'd pull my hair out if I had any left...
Old Mar 26, 2018 | 02:47 AM
holmesnmanny's Avatar
Default Re: 2003 Civic -New clutch won't engage
make sure the clutch pedal has only 1/2 inch of clutch free play, then bleed again
Old Mar 26, 2018 | 06:13 PM
OldJoe's Avatar
Thanks for the reply. It ended up being my own %&@#* fault.... I switched from using a hand operated vacuum bleeder pump to a pneumatic bleeder. With the pneumatic I should have bled with the pedal up. Must have had a small air bubble in the input port of the master cylinder. I must have gone through a fifth of bourbon before it dawned on me.... Oh well, at least the drinks were good. Thanks for the help.
swizz977
11
May 18, 2015 05:05 PM
96civic turbo
Jun 5, 2010 11:09 AM
Liquidgsr
Mar 31, 2007 12:14 PM
RDAYA0
Dec 14, 2006 05:31 PM
