Quick Question 93 CB7
Old Mar 20, 2018 | 06:31 PM
Tikal's Avatar
Icon4 Quick Question 93 CB7
I am in the middle of a h22a swap aswell as a conversion to manual on my 93 accord se. The motor, tranny and gear select have all been taken out. The engine harness from the fuse panel was almost removed. Problem is I need to move the car and the driver window is down.
Question is can I put the harness back on, connect and ground my battery and send power to the door with no issues? Please and thanks fellas.
Old Mar 20, 2018 | 10:22 PM
Tikal's Avatar
Default Re: Quick Question 93 CB7
Bump. Silly question I just want some sort of verification before I go ahead. lol
Old Mar 20, 2018 | 10:29 PM
holmesnmanny's Avatar
i think the only hot wire you would need to worry about is the power wire from the battery to the starter and alternator, but you can pull the driver door panel and apply voltage just to the motor just to roll the window up
there's howto's on youtube
Old Mar 20, 2018 | 10:32 PM
Tikal's Avatar
Good call. I totally would have missed that. Ok I will wrap them in electrical tape before I do it. Anything else I should be cautious of?
Old Mar 20, 2018 | 10:33 PM
if the fuse box is disconnected then nothing is going to work and you'll just need to manually apply power like i said
Old Mar 20, 2018 | 10:39 PM
Tikal's Avatar
The fuse box was not disconnected. I only removed the 2 screws to get the harness out. Adding that back in and putting power to the harness won't get me window power?
Old Mar 20, 2018 | 10:45 PM
then it should get you power
Old Mar 20, 2018 | 10:50 PM
Tikal's Avatar
Ok thanks man, will report back
JGUSH
Jul 20, 2014 07:27 AM
Lakalister
Feb 18, 2012 12:17 PM
luis_ej8
Dec 11, 2011 08:38 AM
Dnyc3st 89
Aug 25, 2010 10:02 AM
rugimpy
11
Aug 16, 2009 08:00 PM
